Adding new clients
BlakeRichardson
Adding new clients
Just a quick query, when adding a client into the dashboard manually how long is this data kept? I.e. if I add a client and they connect and then don't connect again for another 12 months will their defined settings be retained or do they drop off at some point?
I have checked the below but don't see anything that clearly stands out for added client data.  https://documentation.meraki.com/General_Administration/Privacy_and_Security/Cloud_Data_Retention_Po...
RWelch
If added manually it should remain until removed.  An employee that was terminated was mistakenly removed from the network and later added back manually.  We periodically see that same ex-employee pass by (BLOCKED) - and it's remained working that way over the past 3+ years.
RWelch
If you use this option you can see all clients you have manually added with a policy.
I don't think manually clients ever get removed.  I have seen some from a very long time ago.
BlakeRichardson
Thats great, thanks for the replies.
