Dashboard: Page not found
RWelch
Anyone else having troubles logging into the Dashboard?
double_virgule
Are you using SSO? We get that error every few logins on SSO. Trying the login again usually fixes the issue.
I'm able to log into the Dashboard as of 12:25 Eastern and there are no status updates at status.meraki.com.
RWelch
No, not logging in via SSO.  I waited around 5 min and eventually got back into the dashboard.  Weird.
JGill
Sounds similar to the issues on the 10th.  If still having issue make sure to open a case.  the https://status.meraki.net/ dosn't seem to get updated unless several people are calling in.
If you don't have your support ID to open a new case just use an old case or you will get stuck in the IVR.
And because its hard to find when dashboard is down.
Meraki Support number: 415-937-6671  Add it to your phone with your customer number 🙂
