MX75 Latency issue
Charles7
MX75 Latency issue
Hi All,
We noticed that we are having a high latency issue from one of our Network. We are getting a constant 166ms throughout the day. We are wondering if we have a solution to this problem we are experiencing. We contacted our ISP (Bouygues).
and here is what Bouygues told us:
"There is no bandwidth degradation, it is due to the way mainland French network is connected to the Ocean Iden department. The latencies that you are observing are normal. I have tested with another customer (Apave) who has a site in French Guiana and we have latency of around 170 ms. There is currently no solution."
Do we have a way to improve our network latency or this is a known issue?
Thanks for everyone who will answer this question.
10 Replies 10
DarrenOC
hi @Charles7 , latency is a little out of your control unless you reduce the load on the circuit.  What does the loss look like?
Charles7
loss is looking good. 0 - 0.6%.
Starlink?
Charles7
Bouygues Telecom
Shubh3738
Is it constant or latency suddenly increased after some minutes?
Or any services' drop you faced at that time.
Charles7
It is constant
Shubh3738
Which version are you using on MX and MS ?
Charles7
MX 18.107.6
MS 16.7
Shubh3738
You have to update MX to MX 18.211.2
And MS to MS 16.8
It can fix that type of issues.
Shubh3738
@Charles7 , also check firewall utilization.
