Hi Wizards 😁
I have a customer template based setup with ie. MX-65 as SDwan terminators..
When having AP's directly connected to the MX, we sometimes need to recyle the PoE port ..
But .. when bound to the template, there is no access to the port configs / tools ?
How do we go about doing that without restarting the whole device ?
Solved! Go to solution.
Even outside the template you cannot recycle PoE ports on an MX, only on the MS.
Only support can cycle an MX port. You have to call them.
If the MX is not on a template you can admin down admin up the port.
I just tested It and worked as expected.
Yes, I know this is via network, but just create a loop, I think it's much easier this way than going network by network to do it manually.
Wow ! 😀
Thanx Alembrahao!
That was a neat piece of code !! I will do a routine using that (and of course have Your credits in there) ..
Maybe we some time in the future will get same tools for ports in every device ..
