In the MA-INJ-4 Pass thought 2.5G port of the MG51 ?
CharlieCrackle
Is the MA-INJ-4 compatible with the MG51 ??   in particular, does it pass through the 2.5G ethernet or limit it to 1Gig ??
javalins
Hi @CharlieCrackle,
The MA-INJ-4 is an 802.3at Gigabit Ethernet power Injector.  It is compatible with the MG family, but in the case of the MG51 will only provide 10/100/1000Mbps speeds.
If you are looking for 2.5GE connectivity to the MG51, you would require the MA-INJ-6 which is an 802.3bt mGIG power injector.
5 Replies 5
  • Yes, it is. You can read more here.
https://meraki.cisco.com/product/cellular/external-antenna/mg51e/
CharlieCrackle
the data sheet for the MA-INJ4  says    "Gigabit compatible"  where in the link you sent does it say  the MA-INJ-4  is 2.5G compatible...
I'm talking that it's compatible with MG51, if you need more information just open a support case.
javalins
Hi @CharlieCrackle,
