APN settings MG41 v MG21
EliseNemeth
If a customer wants a static IP on their SIM.  It was mentioned to me that it was an “APN Setting” change, which is specifically mentioned in the Meraki documentation but it specifically only calls out the MG41, not the MG21.  It seems to imply that you cannot change the APN setting on the MG21? Please advise because not all customers want static ip.
1 Reply 1
javalins
The APN Setting can be changed on the MG21 the same as it can on the MG41/51 under Cellular Gateways > Uplink.
Change the toggle from default to custom, and you will be able to set the custom APN.
