"Deny Local LAN" setting in the MR Firewall not 100% blocking traffic
whistleblower
Hi all,
During some testing in my Lab, I´ve found out something - in my mind - interessting regarding "Deny Local LAN" setting in the MR Firewall (https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/%27Deny_Local_LAN%27_settings_in_Ci...)
In my opinion that`s not 100% true, because if I´m connected to an SSID (using Bridge-Mode) and I optain an IP-Address from a local LAN in my case 192.168.1.1/24 (Standard-Gateway is a MX Firewall using .254) and the Meraki MR is using 10.10.10.1 as it`s Management IP... regarding the meraki documentation every traffic (exept: DNS and DHCP) destined to 10.0.0.0./8 should be blocked BUT I´m still able to PING (ICMP) the AP on which I´m associated to on it`s Management-IP!
Does anyone of you can tell me if this is a normal behavior and if so, why this is needed or I´m probably facing a BUG?!
what do you think about this?
Sound like a bug. Or they should add icmp  to the documentation.. if thats also allowed.
What happens when you add 10.0.0.0/8 manually as first rule?
whistleblower
that’s what I‘ve tried as well, also with an explicit firewall rule - the same issue! 🙂
I believe the ACL is applied to traffic going out the APs Ethernet port.  It won't affect traffic to the actual AP itself.
