Confine discovery to 1 AP?
RumorConsumer
On my primary user VLAN, I have something like 30 APs and a bunch of wired devices. I have devices that only function locally like speakers and an Apple HomePod that should only be activated by devices in the room and, by definition, connected to the same AP as the speaker. Besides setting up a separate VLAN/SSID combo to segregate the traffic, is there an easy way to bar anybody not on that AP from discovering the Airplay services etc? Also a way to do this that I also do not yet know how to implement would be taking advantage of the fact that only certain devices use those speakers. So I could theoretically only allow certain MAC addresses or IPs to send them data, thus locking all other devices out of being able to send data. Any ideas?
6 Replies 6
I would use a seperate VLAN, however, you can use a single SSID and group policy (assigned to specific devices) to override the VLAN the device is dropped into.
RumorConsumer
Philip you ubiquitous card you. Thanks for the reply. I understand a new VLAN, I dont understand the rest of what you said at all. Can you say more?
The AP the switch plugged into could have 5 VLANs (often going back to an MX).  You can create one SSID.
You create a group policy for each VLAN you want to use, except for the default VLAN that the SSID is configured to use.
So if you create a group policy called VLAN5, and that is configured to drop the user into VLAN5, and then apply that to a WiFi device it will use VLAN5.  It will get an IP address from VLAN5, and only talk to other things in VLAN5.
RumorConsumer
OK I will try to figure this out thank you so much. And just to confirm, what I want is for these devices to have access to everything else on the VLAN like printers in other locations and such things as file servers and what not but have there be a couple devices that can only broadcast into their own access point. Does this do that?
You could need to configure the new VLAN to have that access.
