only allowing one SSID through a specific AP.
Alex-HISD
As the subject states: I'm trying to only allow a single SSID broadcast through a specific AP.
I tried only allowing VLAN traffic for that SSID's VLAN but I had to allow the trunk VLAN as well on the port.
That resulted in the SSID's I don't want being broadcast as well but unable to get DHCP.
5 Replies 5
https://documentation.meraki.com/MR/Other_Topics/Using_Tags_to_Broadcast_SSIDs_from_Specific_APs
There need to be a dhcp server in your vlan or forwarder to a server for your vlan.
BlakeRichardson
This can be achieved by going to Wireless > Configure > SSID Availability.
There you can pick the SSID you wish and scope it to all, multiple or a single access point.
@BlakeRichardson  is on the money.  Put a tag on the AP, and use SSID availability to make it only available to APs with that tag.
Alex-HISD
Awesome, got that fixed so that the SSID is only applied to a specific tag.
Next problem is that this specific AP with this tag is showing the SSID I want, but its also showing all the SSID's I don't want to be broadcast on that AP.
Do I have to tag the other SSID's and assign that tag to every AP except the ONE ap I don't want it broadcast on? Seems kind of silly but I'll do it if that's the only way...
Crocker
This is basically what we ended up doing. We have a handful of SSID's, and each one is tied to a tag. The tags are assigned/unassigned depending on the site needs.
It's extra steps for sure, but after the initial setup it's proven to be beyond useful.
