how chose the best config Minimum bitrate/Radio transmit power range (dBm)
Hamza_iraki
i need your help , on our AP meraki i have this configuration , and i want to know how i can set the best config on my case
on what I have to base myself to design this config for 5ghz and 2.4ghz?
Radio transmit power range (dBm)?
Minimum bitrate?
1 Reply 1
Holli69
it depends on your site survey.
Usually, a good recommendation is a minimum Bitate set to 12 Mbit/s for 2,4G and 5G.
Power Transmit Power for 2,4G should be between 8 and 14 dBm.
Power Transmit Power for 5G should be between 11 and 17 dbm.
Give it a try, but think about your Site Survey (e.g. with Ekahau AI Pro and Sidekick)
