Wireless firmware versions MR 31.1.5.1 changelog Stable Release
SeanW
Important note
Bug fixes
  • General stability and performance improvements
  • Potential crash loops for 6GHz in non-US regulatory domains (Wi-Fi 6E APs)
  • CW916X APs are requesting 40W PoE power when USB is disabled
Known issues
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6, Wi-Fi 6E APs)
14 Replies 14
RaphaelL
I'm just curious , did MR31.1.5.1 went from beta to stable ? I can't recall if it was stable rc or not.
SeanW
Stable Canidate as of today from what I can tell.
KarstenI
Stable as of yesterday.
RaphaelL
Yes I know it was promoted Stable but from what Stable RC or beta. I can't recall.
Paccers
It has been Stable RC for a month FirmwareBot post from that release
Ruch
My AP 9166 was fine on MR 30.7.1. But, when I upgraded the AP to MR 31.1.5.1, it is showing down in Dashboard. Do we need to have additional exceptions in our web proxy ?
SPieroni
I have a site that has a combination of MR42 and MR86 AP's. Per the release documentation MR42's are on the list of SKUs that will be restricted to MR 30.x and will only be upgraded to their latest support version of MR 30.x.  Post upgrade the MR42's are showing a firmware version of MR 31.1.5.1?  Should I expect issues with these devices?
mbxome
So for MR42, to get to 30.7.1, support says you need to upgrade to 31.1.5.1.  But unlike previous releases with a backup version for older devices, after upgrade the dashboard will show 31.1.5.1, which is incorrect.  And you need to contact support to figure out what version you are actually on.  And unlike previous versions, the release notes do not mention that a backup version will be deployed for older devices.
Not good.
KarstenI
Are you referring to the Firmware-Upgrade page? That is only the destination firmware for the network. You see the real running firmware on the Access Points -> List view or on the AP details view:
RaphaelL
I don't understand why they are not attaching a build version to the APs that do not support MR 31.X
TBHPTL
Because it Is all fakery and  forced obsolescence by some ne'er-do-well desk jockey rather then supporting perfectly fine Wave 2 APs that are more than capable of supporting the firmware. Not enough memory or cpu you say? Bullspit is bullspit, dont lie to my face and call it grape soda. Show me a single data sheet that CM has that reveals CPU or memory of anything.
Paccers
Enable AP Device Health EA and see what it runs at under MR30...
DEllerbrock
After upgrading to 31.1.5.1, our GuestWifi SSID is no longer working with the splash page we are using.  Had to rollback all of our MR 33 and MR 36 units firmware.  I have an open case, and the engineers had mentioned other similar open cases, yet I'm not seeing anything on the forums.  Anyone else see this?
hechoinlmusd1
Hi there - There is definitely something wrong with MR 31.1.5.1
We were running on version MR 29.XX and everything was fine.  The Meraki APs all negotiated to either 1000 or 5000 Gbps depending on the Catalyst switch model.  We held off upgrading to version MR 30.XXX because of 802.1x problems that Meraki Support confirmed.  We upgraded straight to latest version MR 31.1.5.1 last month.  Everything was running fine up until this past week.  We then had multiple MR56s drop their Ethernet links to 100 Mbps with Degraded Status.  Looking at the forums, we have power-cycled the switchports and also power-cycled the Catalyst switches.  We have even shut down the APs for half-hour as suggested and powered them back up.   50% of the time, the APs would come back to 1000 or 5000.  The rest of the APs stayed with 100 Degraded.  We checked the cabling and there are not errors.  Something from the latest firmware is definitely causing all these Ethernet speeds to be degraded.
