Wireless clients accessing LAN - Allow or Deny ?
Roey1984
 Hello
 I have the following network configuration:
1. Ubiquity Dream Machine Pro (Router \ Firewall)
2. Meraki MR46 AP x3
3. Meraki MS120 x2
Some users use laptops and connect to the WiFi, while others are with workstations and connected via LAN cable.
If I want users in both WiFi & LAN networks to be able to access each other devices (RDP \ SSH \ CIFS, etc)
Do I need to "Allow" the rule?
WiFi & LAN users reside on the same VLAN (Native VLAN configured in the Ubiquity); it could be tricky to configure VLANs on the Dream Machine Pro and have it fully compatible with the Meraki AP (or isn`t it?)
I`m afraid users can access the Switches and APs from their devices..
So, I guess there isn't a choice but to create VLANs for the AP & Switches (e.g., VLAN 10 & VLAN 11) and additional vlan for the users.
Help would be appreciated.
Thank you!
1 Reply 1
RaphaelL
Hi ,
Do I need to "Allow" the rule?    Yes you need to allow Local lan.
