Paper Mounting Template Explained?
-Michael-
Hi Everybody!
Each AP comes a paper mounting template with A to I (at least on the MR46 version).
I need know what each of these means in terms of mounting the AP, but there seems to be no documentation and support have not been helpful. I get it relates to the holes to use on the cradle, but when/where are these used?
e.g.
A - Standard wall mount, screw in each of the 4 corners.
B - Drop ceiling mount.
C - ?
D - ?
E - ?
F - ?
G - ?
H - ?
I - ?
Brash
I don't know for certain but it seems like the replacement kits have a better explanation
https://www.buymeraki.com.au/meraki-ma-mnt-mr-6-replacement-mounting-kit-for/
2 Replies 2
Brash
Thanks Brash, that is really useful.
It seems older models of AP mounts have this information printed on the card.
Also useful to see examples of the conduit boxes under the mount kits on that site.
