Wireless SSID Authentication using Custom Radius server with Certificate based authentication
ToryDav
I'm looking for a brief explanation on if we can configure Users/Machines to Authenticate to an MR SSID using custom radius (Windows/ISE/Clearpass) with a certificate instead of using credentials.
Is this possible? Is there a guide on how to configure it on the Meraki side?
When I select "my custom radius server" I don't see anything about Certificates in the configuration, this may be transparent to the AP, but I am looking for clarification as it would be my first time with certificates.
I've only configured and tested radius with AD credentials before a few time.
2 Replies 2
stgonzo
Do you have an updated link or a downloaded version, this one doesn't seem to work anymore.  Thanks
