Upgrading home setup – which access points to target?
Andreas_Augdahl
Dear community,
I'm looking to upgrade my home Meraki installation and would appreciate some recommendations.
Current setup:
  • 1x MR42
  • 1x MR36
What I'm looking for:
  • New access points with better performance – I am considering taking the step all the way to Wi-Fi 7
  • License renewal is still 3 months out, so good timing to refresh hardware
Questions:
  • Which current-gen MR models would you recommend for a home setup?
  • Would you consider any other cloud-managed access point models (CW), and if so why?
  • Any particular considerations I should keep in mind when upgrading from MR42/36?
Thanks in advance for any guidance!
Andreas
20 Replies 20
For a complete Wi-Fi 7 experience, I would go with the CW9172I or the CW9176I.
https://documentation.meraki.com/Wireless/Product_Information/Overviews_and_Datasheets/CW9172I_Datas...
https://documentation.meraki.com/Wireless/Product_Information/Overviews_and_Datasheets/CW9176I_%2F%2...
Andreas_Augdahl
Thanks Alessandro!
Quick follow-ups on CW9172I/9176I:
  • Meraki mode experience: Any limitations vs. native MR products when operating through dashboard.meraki.com?
  • Why CW over MR46E? Is this primarily for Wi-Fi 7, or are there other advantages?
  • I read about some issues converting/upgrading CW to MR SW. Is this something I should just disregard?
//Andreas
The CW operates with the same capabilities as the MR.
In the future, the MR  will no longer exist, the trend is for everything to become CW.
You can already purchase the CW with Meraki software without needing any conversion.
Andreas_Augdahl
Okay, thanks a lot for the clarification.
Are these the correct SKUs?
CW9172I-RTG
CW9176I-RTG
//Andreas
To be honest, I've never heard of RTG. To me, the correct SKU should be something like CW9172I-MR, but I confess I'm having second thoughts now.
Andreas_Augdahl
Thanks anyway, I'll get in touch with our Cisco partner manager here in Norway – I am sure we'll be able to figure it out.
Thanks again!
Mloraditch
Those are the skus that come with the default bracket and accessories. The CFG skus allow you to customize the brackets. You will see them both and explanations when loading in CCW
Andreas_Augdahl
Thanks a lot — I'm learning to decode the explanations in CCW and think I've reached the conclusion that the RTG SKUs are right for me.
RTG = "Ready To Go"
AndyEspo
We do a lot of high-end residential networks with Meraki systems. IMHO. unless you have one of the very few brandy-new computers or phones that support WiFi 7, it's likely you won't see any performance difference between the MR36 and the CW APs. Better to get one used MR36, replace the MR42 and wait on the WiFi 7 APs until there's more device support and the AP prices come down. Cabling, termination quality, switching and AP placement matter, as always.
Andreas_Augdahl
Thanks, I appreciate it, but I really would like to future-proof my setup when I decide to upgrade.
rhbirkelund
What is the purpose of your Home setup? Labbing?
If you are going to use them in order to lab different setups, I'd go with 2x CW9176-RTG, and perhaps spice it up with an additional CW9172H. Look into getting the MR Advanced license, as it will give you access to AI-RRM features.
The -RTG or Ready-To-Go SKU is the one to use, as @Mloraditch points out. The -CFG SKU is used, if you plan on orderings lots of them, and need specific packaging options, like omitting the bracket.
RTG is built to stock, which means it is ready to be shipped, and comes with mounting brackets. With 917x APs there is no longer the concept of fixed regulatory domain APs as we know it from 916x or earlier.
In addition to the APs, if you are going with 9176, to get the full experience, look into also getting a UPOE switch to power them. They can boot with PoE+, but with reduced capability.
rhbirkelund
If you are good friends with your Channel Partner, and they can hook you up with CW9178, that'll be nice. 🙂
BlakeRichardson
Remember for Wifi 6 and 7 you need mGbit switching
Take a look at this excellent post by @MerakiDave showing the migration path for different APs.
https://community.meraki.com/t5/Wireless/Family-Tree-Meraki-MR-to-CW-Access-Point-Generations/m-p/29...
Andreas_Augdahl
Anyone,
I see from MerakiDave's family tree that CW9176I is the WiFi 7 successor to MR56.
Two clarifications:
  • Does CW9176I-RTG ship Meraki-ready, or does it require conversion from IOS-XE?
  • Will CMNA program licenses cover CW models in Meraki mode, or are separate Cloud Management licenses needed?
Trying to understand if CW9176I is truly plug-and-play Meraki?
Thanks!
rhbirkelund
If you have a controller locally, that the 9176 can discover, it will join that. If it cannot find a controller to join, it will boot up in Meraki persona.
You can also fasttrack it by using Fast Offline Migration (FOM) by using option 43 on a DHCP server.
If you have Co-Term MR licenses, you can still use the CW APs.
Andreas_Augdahl
Cool, thanks.
MerakiDave
Hi @Andreas_Augdahl
I was taking a peek at some of the replies, all good stuff.  If you're moving on from MR36 and MR42 and want to stay in the mid-range of the Wi-Fi 7 family, CW9174I could also be a great choice, and if you only have 30W PoE then the 9174 models are fully functional from a Wi-Fi perspective even on class 4 power, you won't lose any spatial streams, all client serving radios plus the IoT and Scanning radios are all on.
With only 30W on the CW9174I/E, what you lose is some power on the USB port (9W down to 2.5W and you likely don't care, unless you're simulating a retail environment in your home lab with ESL dongles) and the 5Gbps mGig port drops to 2.5Gbps, that's it.  And if it's a 30W switch port and maybe also only 1G then you may also not care about 2.5 vs 5Gbps for the uplink.
All that said, if you've got 60W and/or mGig, go for it with a CW9176I or CW9178I.  They are absolutely more capable and higher horsepower APs.  The newer mid-range 9174 is not a "stripped down" 9176, it's more of a "souped up" 9172.
On your other question about ready to go for Meraki out of the box, yes.  Regardless if you order -RTG (ready-to-go with default low profile mounting bracket) or the -CFG (configurable) to customize the brackets you want, all of the CW (Cisco Wireless) CW917x Wi-Fi 7 APs are "Global Use APs" and it's fully converged dual-boot hardware, with subscription-based unified licensing.
The AP will determine out of the box, with no priming or prepping, if it belongs in a Meraki Dashboard or on a WLC.  And you can also convert it back and forth on Day2+, bidirectionally, without a support ticket, so that's nice if you also have a WLC in your lab and want to use both personas over time.
For any other readers coming across this thread in the future, I thought this is a good spot to describe the GUAP process, here's a Global Use AP slide below and a bunch of notes.
There are two key things about a "Global Use AP".   First, we have decoupled the AP PID/SKU from the boot mode (all GUAP APs can be on-prem or cloud-managed), and 2nd we have decoupled the AP PID/SKU from the regulatory domain in which it will operate.
There are 4 sections on the slide for days 0/1/2/3, but in reality, days 1/2/3 could be any indefinite length of time (not literally 1 day). 😉
On day 0, the very first boot out of the box or after a factory reset, there is a GUAPO process (Global Use AP Onboarding) that determines the management mode automatically.  Once it knows to either join a controller or join a dashboard, it will stay that way on day 1, regardless of any reboots, unless it’s later migrated on day 2, or factory reset on Day 3.
The first thing out of the box on Day 0, the AP first checks if it’s got connectivity to the cloud and if it has been claimed into a Dashboard Org and perhaps also assigned to a network.  If so, great, it’s off and running.  If there’s no connectivity to the cloud or it’s NOT claimed into a Meraki Org inventory, it begins the search for a WLC and continues with that onboarding process.
So if it’s a Meraki customer, basically nothing changes whatsoever, and it’s as transparent as possible to the customer: Claim the AP's serial number which is now called the Cloud ID (or claim an order # of many Cloud IDs) then it’s plug and play.  The only caveat being if that customer has a hybrid deployment of both Meraki and controllers for different parts of their deployment, then there’s a little more to pay attention to.
If it’s a classic controller customer, you power up the AP, there’s no Meraki Org for it to live in and/or no Internet access, and it begins the search for a WLC (or Cat Center).  If it finds a compatible controller, it reboots into WLC mode and joins the WLC like normal with CAPWAP discovery (which includes DHCPv4 Option 43, DNCPv6 Option 52, DNSv4, DNSv6, Broadcast IPv4, Multicast IPv6, or Static assignment), or we have plug and play with Cloud PnP or Pnpserver.<localdomain> for CatC.
One more cool thing, in the case of on-prem APs on WLAN controllers, in addition to the AP auto-determining its boot mode (cloud/dashboard vs on-prem/WLC) it will also determine its regulatory domain.  So for on-prem, when ordering, there are no more county codes like -B or -E etc.
After joining a WLC, it then determines which country it should be operating in, in which case it’ll check 4 things, in the following order.  The 1st is via GPS/GNSS, 2nd is by proximity via nearby APs within RF range on the same WLC.  A 3rd way is via migration from Meraki Dashboard to WLC mode and it’ll retain the country code that was in Dashboard.  This is the “Migrate to WLC” button on the AP flex table page (API works too) and the APs will retain the country code.
And the 4th and final (failsafe) way is with a regulatory activation file which can be downloaded from Dashboard and installed on a WLC.  This last one will be rare, but it’s a last resort, cryptographically signed but human-readable file generated off the Meraki Dashboard, thrown onto a USB key and sneaker-netted to a WLC to authorize a list of S/Ns to operate in a given country.  So if you happen to be in an underground bunker with no GPS, no Internet or Dashboard access, no other APs whatsoever, then we've got you covered there too. 😁
Hope that helps!
A bunch more info here: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/technical-reference/global-use-ap-dg.htm...
Andreas_Augdahl
@MerakiDave– this is exactly the level of detail I needed. Incredibly helpful.
The GUAP process explanation cleared up all my questions about conversion complexity, and the PoE clarification (30W vs USB fallback) is critical for my switch planning.
CW9174I looks like the right choice for my setup – WiFi 7 future-proofing with manageable onboarding process.
Really appreciate you taking the time to break this down so thoroughly!
//Andreas
MerakiDave
Great, glad that helped.  If you want to stay in the mid-range, 9174I seems sensible and especially if you have limited PoE/mGig.  The CW9174 is a well-balanced Wi-Fi 7 choice with full tri-band Wi-Fi 7 capability, but without requiring 60W PoE or 10G switching to get meaningful benefit even if the 60W/mGig is not in your wired infrastructure (yet).
So if you're limiting factor for now is 30W and/or 1G ports, while you might not realize the full benefits of 9176/9178 until you refresh switching, the 9176/9178 certainly step things up with more total radio capacity, 10G ports, and higher horsepower in general for high-density and more demanding enterprise environments.  And 9178 adds the 2nd 10G uplink port and the 4th client-serving radio so you can have full-time 2.4/5/5/6GHz.  But going back to your original post, if this is for your SOHO environment and coming from MR36/42, I think the mid-range 9174I fits well.
In this case, the CW9174I gives you the Wi-Fi 7 feature set and future-proofing but without over-investing in horsepower you may not immediately utilize until the wired side is refreshed (and might not ever really need or utilize in a SOHO deployment).
