Unable to blink or restart AP from meraki cloud
Knowledge_gainr
Dear Team,
We have huge network of MR 36 and MR 44 AP's but we are facing AP hanging issues.
Like unable to blink AP LED or restart it from meraki cloud also having splash page issue.
Thanks in advance,
RohanP......
14 Replies 14
Is the AP online on the dashboard?
I suggest you open a support case.
Knowledge_gainr
@alemabrahao
Yes, it is online.
In this case, I believe that only support will help you.
rwiesmann
You could try to powercycle the Switchport (and with that the AP), where the AP is connected...if you have meraki switches...that should be easy.
If it does not work...I would also proceed with a support case.
hope that helps
roger
Knowledge_gainr
No, we Dont have meraki switches.
DarrenOC
Hi @Knowledge_gainr , sounds like some form of miscommunication from the devices to the cloud.  Are you seeing any blocks/drops on your upstream firewall?
Knowledge_gainr
No,there was no blocks/drops on your upstream firewall.
Block on firewall means?
Are you running a current stable firmware or better?
Knowledge_gainr
Yes, We are running on 30.5 firmware.
Knowledge_gainr
Can i get meraki dns ip address?
TBHPTL
Meraki doesn't have an AP DNS address per se, this information comes from your upstream gateway/DHCP server or you have it hard coded, in which case you should already know it. For Meraki anything to talk to the cloud the following must be met:
https://documentation.meraki.com/General_Administration/Other_Topics/Upstream_Firewall_Rules_for_Clo...
CFStevens
Hi @Knowledge_gainr
I would advise navigating to Wireless > Monitor > Access Points > [SELECT AP]
Once on the AP status page, check and make sure that the CONFIG section on the bottom left of the dashboard says that is up to date.
Knowledge_gainr
Dear  CFStevens,
It's up to date of version 30.6.
CFStevens
Hey @Knowledge_gainr
Thank you for those details!
If that is the case, a factory reset followed by a re-test may be in order. If that still fails, then I would advise giving the Meraki Support team a call so we can investigate the issue while someone is on site to make sure everything is in order.
