We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Does Meraki APs have any logic/feature that can help the wireless clients switch to their cellular network e.g. LTE, when their WiFi connection is poor?
Solved! Go to solution.
the AP does not know a client has also a lte modem with working sim. So this would be something you do client side. I know android has this. And windows you should be able to configure this https://www.tenforums.com/tutorials/149276-change-when-use-cellular-instead-wi-fi-network-windows-10...
