- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Splash created with radius server is not working with actual AD credentials
Hello Everyone,
I have created Radius server for splash page authentication to access the internet. Splash page is reflecting on user devices but AD credentials are not working properly. If user is typing anything in username and password it is allowing the access to internet which means t is not checking for AD actual credentials and anything which we are typing randomly it is taking that garbage also as a credentials and allowing to the internet access.
I have done below mentioned settings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you share your SSID configuration?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To use splash page your server must be reachable through the Internet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You have created an outbound rule, is traffic allowed to the radius server from the Meraki APs/cloud etc.? You need an inbound rule to it. In terms of the behaviour it is expected as the RADIUS server is unreachable and you have said to allow access if that happens, hence they can type anything.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I tried with Inbound rule as well, but still it is behaving in the similar way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you tried using the Active Directory authentication rather than RADIUS?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @CameronS
Yes , I tried. In AD case , while user was typing username and password , it was showing error "Access Denied" on splash page every time and users were not able to get connected with internet. So i used Radius which is at least allowing to get connected with internet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You could try using the AD auth but on the client device, set the network adapter settings for the VPN as below:
