An MR46 shouldn't need anywhere near 30W in normal operation, the second one down here is an MR46E as seen from the Switch/Ports view:
Incidentally the 3rd is a CW9166i, showing again that not nearly peak power is used.
What do you see on this view, or are you not using Meraki switches?
