Rogue Reporting- need an API (or suggestions)
Jamieinbox
Hi, I see these API details for Air Marshall:
https://developer.cisco.com/meraki/api-v1/search/?q=rogues
APIs available listed below.
I need a way to report on the different networks across the org, so:
1- They have a list and can begin categorizing
2- We can run regular reports to share data and tack progress.
-Any way this can be accomplished now?
APIs Here:
Create Network Wireless Air Marshal RuleAPI
Update Network Wireless Air Marshal RuleAPI
Get Organization Wireless Air Marshal RulesAPI
Update Network Wireless Air Marshal SettingsAPI
Get Organization Wireless Air Marshal Settings By NetworkAPI
Much Thanks.
Jamieinbox
7 Replies 7
GreenMan
Meraki Alumni (Retired)
I think this might be the endpoint you need:   https://developer.cisco.com/meraki/api-v1/get-network-wireless-air-marshal/   this is a per-Network call.
Jamieinbox
Thank you! Will dig on this.
Jamieinbox
This API pulls great info. Thank you. Any suggestions on how to get only the Rogue SSIDs?
GreenMan
I'd expect some content, for a rogue in one or more of these :
"wiredMacs": [ "00:11:22:33:44:55" ],
"wiredVlans": [ 0, 108 ],
"wiredLastSeen": 1526087474
Jamieinbox
Perfect- thank you!
Jamieinbox
Thank you. I made this:
Merakicode/RogueAirMarshallAllIn1CSV at main · jadexing/Merakicode
Pretty happy with this.
CarolineS
Thank you so much for sharing, @Jamieinbox! I have just adjusted the marked "solution" to be this post with the code linked (instead of the earlier "Thank you! Will dig on this." reply :-)).
