- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Number of SSIDs I can use ?
Hi I have 50 Meraki WAPs setup with User and Guest SSID on all.
Some WAPs are in other buildings and I want to add some new SSIDs to these to look like this.
Building 1 - User, Guest, VOIP, CCTV
Building 2 - User, Guest, VOIP, IOT
Building 3 - User, Guest, VOIP, AV
Building 4 - User, Guest, VOIP, Mobile
Building 5 - User, Guest, VOIP, Scanners
Questions. Am I limited by SSIDs across complete meraki system.
Can I have different groups of WAPs setup as above.
How do I put APs in a group to enable the above SSID selections on them.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No more than 3 SSIDs should be enabled on any single AP. Each SSID should have band-steering enabled. Legacy bit rates should be disabled on each SSID. Only enable an SSID on an AP if needed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Max is 15 ssid for a dashboard network.
For ssid broadcast per ap
https://documentation.meraki.com/MR/Other_Topics/Using_Tags_to_Broadcast_SSIDs_from_Specific_APs
You can also look into ipsk if your goal is to put different devices in different vlans
https://documentation.meraki.com/MR/Encryption_and_Authentication/IPSK_Authentication_without_RADIUS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What is the max SSIDs that I should assign to each WAP or tagged group of waps ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
WPN via iPSK is the better option here, allows for more PSK then vanilla iPSK
https://documentation.meraki.com/MR/Encryption_and_Authentication/Wi-Fi_Personal_Network_(WPN)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Just be aware the more SSID you add the more overheads you are adding to your access points.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can also use two additional features within the dashboard to help you make the decision
Network Like Yours allows you to compare your current setup versus other networks of the same characteristics
Summary Report to check the usage of particular SSID to justify whether it's still needed or not
