Non-TCP Web Traffic
JohnUK
Non-TCP Web Traffic
Hi
I have one of our clients using the wireless network with a high consumption of data.  It has categorised this as Non-TCP Web Traffic, is there anyway I can find out what this is?
Uberseehandel
have you considered asking them what they are doing?
10 Replies 10
If hostname visibility is enabled then you can usually figure it out based on where the traffic is going to.
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Hostname_Visibility
JohnUK
Thanks for the reply.  I have enabled this & it looks like they are using some proxy server to access various.  Can I just block non-tcp web traffic?
You can make a group policy with some L3/L7 firewall rules & shaping and attach it to the specific client.
JohnUK
I have created policy for this person & attached the below firewall rule to allow ports 80 & 443 only.  Will this work?
a deny any would be your last rule not the first.
port 443 also would be on tcp.
JohnUK
Thank you, so the below is correct - Just got to bare with me, new to creating rules
adding a deny any is very restictive since the client probably also need to reach services like dns dhcp ntp
JohnUK
The issue I have is that I have blocked all P2P & they seem to be using different ports to get to WEB, I presume to stream some video via a proxy connection.
Uberseehandel
Dylan_YYC
LOL! im sure they'll come back with "oh, nothing it must be something in my computer"
