Would there be instances where a user would use both physical interfaces on an MR device? If so, would they ever use both to separate traffic between SSIDs?
Thanks in advance!
Solved! Go to solution.
Only the MR53 and above have two interfaces, and they are only used to increase the bandwidth to the AP using channelling/bonding.
https://documentation.meraki.com/MR/Installation_Guides/MR52%2F%2F53_Installation_Guide#Ethernet_Por...
They can not be used to separate traffic between SSIDs.
@PhilipDAth
Thank you!
