No name SSID sent by Meraki AP
rwiesmann
just noticed today that my mr32 to sends out an additional ssid with no name.
The only ssid which i have configured is the Net-Impact with WPA2.
Can someone tell me why i see an additional ssid with no name and WEP?
many thanks
roger
6 Replies 6
https://nolanwifi.com/2017/02/06/merakis-mesh-mess/
You can turn off mesh @ Network-wide > general
rwiesmann
That's it! Thanks a lot
Nash
Strong recommend to reboot your APs again after you disable meshing. I disabled meshing across a couple hundred APs on a few dozen networks a few weeks ago, and about 2-3% (ish) woke up and wouldn't let devices associate reliably.
After rebooting the grumpy APs, they were fine.
NolanHerring
It's been my experience that when you enable/disable MESHING, it automatically reboots the AP each time. Tested this on several occasions. However I have ran into a few issues with AP's not responding as well, which is why I setup my weekly AP reboots. In code 24.X, disabling MESHING was a VERY bad idea lol. It wasn't until 25.X that they fixed it so that it wouldn't cause issues (however a few still sneek in every once in a while, but it also might just be general bug and not related, who can really tell these days).
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Nash
I had the APs reboot when I disabled meshing, but then a small handful wouldn't let devices associate. Had to reboot that handful a second time.
Richard_W
So advantages of Meshing: are there any?
I think it is on by default. Any input from the wise, and Meraki Employees?
