New MR 30.7.1 stable release candidate: client balancing, RADSec and VLAN override fixes.
Wireless firmware versions MR 30.7.1 changelog
Important note
Legacy product notice
  • When configured for this version, MR12, MR16, MR18, MR24, MR26, MR32, MR34, MR62, MR66, and MR72 will run MR 26.8.3
Bug fixes
  • General stability and performance improvements
  • Client balancing rejects clients when the 9th or 10th SSID is enabled
  • AP instability when RADSec is enabled (Wi-Fi 5 Wave 2 APs)
  • VLAN override fails on SSIDs configured to use VLAN ID tagging
Known issues
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 5 Wave 2 and Wi-Fi 6 APs)
RaphaelL
You will have a hard time finding that kind of info here. Best suggestion would be to contact your SE or support directly
9 Replies 9
RaphaelL
Are the 4 new fixes considered as known issues in older firmware such as MR30.7 ? Absolutely not.  Sigh.
RO
Yup they were not in the known issues. I came to know of client balancing issue after I experienced it and called Meraki support
Currently having Radius SSO issue at the moment in my environment. Won't surprise me, if it's also known issue in version 30.7
Mloraditch
I'm just grateful the fix is out. I've had new SSIDs staged in the 9/10 slots for a few months and during testing got caught up in the bug. We have yet to actually make live the new setup and now I won't have to redeploy everything.
RaphaelL
But my point still stands. Meraki was aware of the issue , worked on the issue without ever disclosing the issue. I don't understand what are they gaining by doing so.
Karl_Jacobsen
Soooo, how long does it take for a firmware to go from "Stable release candidate" to "Stable"?
The more people who use it, the quicker it moves!
MarkH
Where can we find out more information about the bug fixes? "General stability and performance improvements" is very cryptic.
We use VLAN ID tagging on some of our SSIDs so it would be good to know more details about the bug. What triggers it or is it random? How often? How can we identify it?
RaphaelL
hjrecorte
Has anyone used this version? Have you encountered any bugs
