Meraki Heat map design
Truonghd
Dear all!
I am finding the tool to design Heat Map to setups the number wifi Meraki from the office to the customer.
Please suggestion!
Thank you so much and have a nice day!
7 Replies 7
Inderdeep
@Truonghd : this may help you
https://apps.meraki.io/details/vapp-wi-fi-coverage-survey/
Regards/Inder
www.thenetworkdna.com
Thank you so much for your quick support.
Does this software need to buy the license, right?
Thank you so much!
Inderdeep
@Truonghd :you can sign up for a 15-days free trial. Free Trial enables you to explore the app with no limitation. You may buy a subscription at any time during the trial period.
Regards/Inder
Inderdeep
@Truonghd : Let me know if any further assistance required. Good Luck !
Regards/Inder
DarrenOC
Hi @Truonghd , I honestly think you need to consult with a third party to provide you with a professional site survey.  It’s not something you should do off your own back with a piece of software you have no experience with.
@DarrenOC agreed! A true wireless site survey takes hours of work and looks at a wide range of variables. Software is not always a reliable method more of a guide, real world testing with hardware is something you should do before you submit an order no matter what brand of AP you are choosing.
Truonghd
Dear @DarrenOC : thank you for your support.
Sorry for late reply. I took off 1 week and today back to work. Before buying and putting into practice. The company asked me to do my own research and learn how to operate. I have logged into the link you sent above but still don't know how to use it. 😞
