MR86 Antenna Frequencies
gcarmich
Do all 4 of the MR86 antennas transmit all supported bands of the MR86? or are some dedicated to 2.4GHz and others to 5GHz?
Brash
From the installation guide:
"Both 2.4 GHz and 5 GHz client serving radios are diplexed onto each antenna port, so if using multiple antennas it is best practice to aim all in the same coverage area."
5 Replies 5
Features
Dual–radio aggregate frame rate of up to 2.98 Gbps*
5 GHz 4x4:4 radio and 2.4 GHz 4x4:4 radio offer a combined dual–radio aggregate frame rate of 2.98 Gbps*, with up to 2,402 Mbps in the 5 GHz band and 574 Mbps in the 2.4 GHz band. Technologies like transmit beamforming and enhanced receive sensitivity allow the MR86 to support a higher client density than typical enterprise-class access points, resulting in better performance for more clients, from each AP.
For more details check the documentation.
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR86_Datasheet
gcarmich
I dont see documentation on frequencies per antenna port.
Refer the installation guide.
https://documentation.meraki.com/MR/MR_Installation_Guides/MR86_Installation_Guide
gcarmich
thank you!
Brash
