MR70 Mounting
DerikA
MR70 Mounting
I acquired several MR70 access points to deploy in a cross dock (narrow warehouse with semi bays on either side) that is often open to the elements. Now that I have them I see the mounting plate is very different than other Meraki access points and made of plastic. Does anyone have any suggestions on how to mount these to I-beams? On the normal access points I have been buying clams, attaching them to a low profile electrical box and attaching the mounting plate to that but with the smaller plastic plate it does not have all the mounting options.
Thanks for any suggestions.
2 Replies 2
Inderdeep
@DerikA : Did you check this
https://documentation.meraki.com/MR/MR_Installation_Guides/MR70_Installation_Guide
Regards/Inder
www.thenetworkdna.com
DerikA
@Inderdeep thanks for the response, yes I had looked that over. My concern, which maybe unwarranted, is the lack of options for how to screw the mount down when compared to a normal mount and the mount being plastic. I've been thinking about using small self tapping screws but I am worried about damaging the mount when screwing it into place. Hence the ask to see how other people have been mounting MR70s.
