MR44: Using DHCP instead of the Static Address Assigned
mcoomber
I've just taken delivery of 9 MR44. I've configured each to use static assigned IP Address but somehow these APs are collecting DHCP from the DHCP Server on the LAN. These AP are connected to MS130P switches. I've disabled DHCP on the switches.
The MR36 that is also connected to the same switch is using the assigned static IP Address.
Two of them are acting as repeaters.
Any ideas why this might be the case?
Thanks.
Are you assigning a ip in the native switch port vlan?  If so, leave the MR vlan field empty
6 Replies 6
Shubh3738
Simply assign a static IP address to the MR (Meraki Access Point).After the IP assignment, please cycle the switch port to which the MR is connected.
mcoomber
This is already done but still using DHCP Address.
Shubh3738
Are you rebooted after after applying.
probably fix this
mcoomber
I've done several reboots over the past two days.
mcoomber
Thanks very much for the support
