Auto connect on SSID barely work .
tli_1
Hi Guys,
Having Radius managing corporate clients to authenticate on SSID , some clients facing this behavior about windows prompting to enter their credentials at each logon ,i believe it should be entered  once and the rest of days automatically, can someone here give a clue on this to where i have to look.
Thanks !
5 Replies 5
Are you manually configuring the connection on the machines?
tli_1
If i understand correctly, NO .
Is it possible to forget the network and try to add it manually? This is a known Windows issue.
tli_1
Thank you , tried this in the past with no success. I think i should investigate on windows side instead.
