I have a network but not all AP's are active. If I do the upgrade to the entire network, do the inactive AP's will upgrade as well without any trouble or incident?
Solved! Go to solution.
What is a inactive ap?
AP can only upgrade if its connected to the cloud.
If you upgrade the network fw for APs, and a AP is down, it will upgrade fw next time it connects the cloud.
The AP is in the cloud but the status of some of them are "dormant", "bad" or "alerting"
Any that aren’t registered to the cloud won’t upgrade
