- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
C4W configuration
Hi everyone,
I ask your support for a problem that sad me.
I have configured the MR70 parameters as written in the Meraki documentation but the splash page doesn't appear.
I have already put the C4W server IP in the walled garden and inserted the external splash pahe URL but the situation doesn't change.
Anyone know how to help me?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello Mark
First Step :
be sure that your VLAN Guest is propagated proprely on all interco ports + AP ports (if any)
Second step :
Create your Guest SSID
Association requirements: Open
Splash page Sign-on with : My RADIUS Server
RADIUS for splash page : Put C4W Radius Servers (1812 Port Auth and 1813 for Accounting)
configure walled garden
Addressing and traffic : Bridge mode + TAG the vlan ID (if any)
then
go to Wireless => Splash Page :
Custom Splash URL : Or provide a URL where users will be redirected : put your C4W Splashportal URL
Splash Behavior A different URL : put your C4W Splashportal URL
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ok, it sounds like you are wanting to configure your AP for a 3rd party RADIUS provider. I have never heard of C4W but should be the same.
There are two spots to that you have to do this:
- Wireless-->Configure--> Access control this is where you establish your RADIUS credentials /Walled Garden etc. on a per SSID basis.If you have done thi properly you will see an OK for your RADIUS server
2. Wireless-->Configure-->Splash Page. Again, set on a per SSID basis.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Could you post a web link to the product you are using?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello Mark
First Step :
Second step :
then
