IOS text message Attachments
Djarz
I recently installed an MX-75, MR46 & 9164 in my home. I am noticing that IOS text message attachments are are not being sent and received. If we switch to cell, they work just fine. The firewall is at the default and amp is turned off. The IOS devices are not managed either. Any thoughts?
14 Replies 14
Is the content filtering enabled?
Djarz
Content filtering is off
Are you talking about the text messages you receive via your cell phone provider? It doesn't make sense since what is filtered is network traffic.
Can you explain in a little more detail?
Djarz
You bet, IOS (imessage) is working, but the attachments will not download. If we get all IOS devices off the wifi and onto cell, it works. I just moved IDS to mode "detection" for testing. AMP is all. Firewall is default
I found this discussion, but I personally still don't see the point.
https://community.meraki.com/t5/Security-SD-WAN/Is-my-MX-blocking-iOS-messages-with-media/m-p/39656
Djarz
Yes, I saw this article as well. The point is that something within the iOS text message attachments.  I agree with this article. I think it’s a port that’s being blocked somehow for iCloud back up. Attachments are stored in an iCloud first and then forward
Kolt601
We have the same problem with managed or unmanaged iOS devices.  The MR Layer7 firewall rule for denying 'online backup', iCloud is part of that. Access to iCloud is what is breaking text messages (iMessage) that contains pictures or a video.
Djarz
Perfect let me take a look at this.
That's what the discussion I sent says, I don't think you read it. LOL
Djarz
Oh, I read the discussion. It just didn’t have much detail. Maybe I didn’t dig into the thread far enough to find it, but the last poster had some screenshots.
Djarz
I looked and there are no Layer 7 rules in play. I did move intrusion detection from prevention to detection. So far, so good. I am still testing
BlakeRichardson
Given everything is set as default i would open a support ticket.
But also run a packet capture and see if you can see anything that looks out of place.
What are you using for DNS? Maybe try Google 8.8.8.8 and rule out DNS.
Djarz
Yeah If it keeps happening, I will open a ticket. DNS is 1.1.1.1 and 8.8.8.8
Djarz
hmm, I removed 1.1.1.1 and did some research, seems Cloudflare may be messing with it too. I will keep testing. thank you
