High Density AP's
savoba-DPS
High Density AP's
Looking for suggestions on the best high density AP's for a school hallway setting.
CW9166 has the most radios for a high density AP, you can have two set to 5GHz so twice as many clients.  The CW range is also the future path for all Meraki APs.
I think the most important thing than the model is the definition of a good design. Generally an HDX environment brings some challenges.
If you don't have experience with the topic, the ideal is to hire a specialized company.
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
BlakeRichardson
Higher spec models are the way to go but as mentioned already get a site survey done. Simply blasting AP's on full power isn't the way to go as you are likely to get a ton of overlap and end up with large amounts of interference and an overall bad time.
