INTEGRACION MR CON NAC
Sarapoveda
Just browsing
Buen dia
requiero de su amable ayuda,si alguno ha realizado integracion desde MX hacia nac, ya que no cuento con información del tema
5 Replies 5
From MX or MR? Which NAC are you using?
Sarapoveda
Just browsing
buen dia
el nac se maneja virtual y la version es 8.5.2 -Forescout,quisaz tendrian una paso a paso
I think you need to check the Forescout documentation.
https://docs.forescout.com/bundle/802-1X-Plugin-Configuration-Guide-4-2/resource/802-1X-Plugin-Confi...
GreenMan
With MX, you will want to start here,   I think - at least in terms of the MX technology:   https://documentation.meraki.com/MX/Access_Control_and_Splash_Page/MX_Access_Policies_(802.1X)
You will though carefully want to think about and document what your policies are going to be in regard to this;    who is allowed to connect?   Where, When? and using what devices?    What resources are the various combinations allowed to access?    Just for examples...
You may find that implementing 802.1x (NAC) is much better done on Access Points and/or Switches - they generally provide initial connectivity to the Network and (in the case of switches) have more advanced capabilities.
Sarapoveda
Just browsing
buen dia
el nac se maneja virtual y la version es 8.5.2 Forescout,quisaz tendrian una paso a paso
