Viewing Clients Connected between XX:XX and YY:YY
Ryan2024
Is there a way to view clients that were connected to an AP during a specific time frame? The event log shows you events before a certain time which kind of works, but it's unwieldy to wade through all the events in a long time frame - even with filtering.
kYutobi
Meraki doesn't provide a built-in feature to view a historical list of clients connected to an AP during a specific time frame. The event log is your best option, but as you noted, it's cumbersome for detailed analysis. Use filters in the event log to narrow down by SSID or MAC address or export the event log and analyze it externally in a tool like Excel or a script to parse the data.
Enthusiast
2 Replies 2
kYutobi
Enthusiast
If you use WPA2-Enterprise mode authentication you could check your RADIUS server logs.  If you are using Windows NPS as your RADIUS server, filter the security log on the NPS server for Event ID 6272.
