Any chance the printer has a wired connection option, and that there is a Meraki switch port near by ? I believe switches can send an alert on status change of any port. The catch is, it alerts on "any port" change, not a specific port. so not a problem if the switch is a MS220-8P with infrastructure pieces (servers, AP, modem) on it - but if its a 48 port switch with end users the idea is not applicable.
