Different AP models
markus_albisser
Different AP models
Hi all We have MR45 APs in place in one of our offices, now we need to extend this office with more APs. MR45 APs are end of sales and I want to go with MR44, from the roaming prospective is the MR45 compatible with MR44? Or are there any issues? Of course there exists a table which models best can be "mixed" within one Meraki network? Thank you Markus
Brash
There's no explicit compatibility table for mixing AP.'s, just general best practices.
As they're both 802.1ax AP's, you should be fairly save mixing them in the same environment.
Brash
If you also still using 2.4ghz band, you could also look at the mr46. That support 4x4 on 2.4ghz like the mr45 does.
markus_albisser
Many thanks to both of you for the opinion. I then will check which model can be delivered faster.
