Meraki Cloud Authentication - Simultaneous Login
JohnEustace
I know it's not very scalable but for a temporary solution I've been asked if there's a limit to the number of clients that can connect to an SSID with one set of credentials in the "User management portal".
Can't see anything documented.
unfortunately it is not possible, the options are limited.
Try this:
JohnEustace
I think that's for a splash page?  I'm talking about the "Enterprise with Meraki Cloud Authentication".
JohnEustace
Thanks.  I did wonder as I couldn't see any reference to it anywhere. 👍
