Current Firmware Version of Meraki AP
erhanevgin
Hello team
What is the current firmware version of Meraki AP and the MR 29.3 firmware is  beta?
EJN
You can rollback/undo for 2 weeks. After that you can't. If this is your situation, I recommend opening a case in the Dashboard for support.
The rollback button is the undo arrow icon in the Firmware screen in the dashboard.
https://documentation.meraki.com/General_Administration/Firmware_Upgrades/Managing_Firmware_Upgrades
Esteban J Nunez
School and Church
K-12 Education
6 Replies 6
EJN
This information is available in your dashboard under Organization / Firmware Upgrades.
MR 28.7.1 is the latest. 29.3 is beta.
(I'm on 29.3)
Esteban J Nunez
School and Church
K-12 Education
erhanevgin
@EJN  thank you for your answer. Is there any way go back beta version to stable version?
erhanevgin
we have some trouble on beta version 29.3 we are getting following error messages on dashboard Meraki AP ERR.JPG
EJN
This particular message may indicate the MR56 is unable to connect to the Meraki Cloud. What is the status showing in your dashboard? Are your other MR devices OK? (or MS or MV)?
What color do you see in the MR device?
Can you try a hard reset with the physical pin hole in the MR?
https://documentation.meraki.com/General_Administration/Support/Resetting_Cisco_Meraki_Devices_to_Fa...
Esteban J Nunez
School and Church
K-12 Education
EJN
Esteban J Nunez
School and Church
K-12 Education
erhanevgin
@EJN  you are right. other APs are working well we just lost MR56 and rollback options not available.
Thank you
