Meraki integration possibilities - AIR-AO1832-Z-K9 / Controller C1-AIR-CT5520-K9
FabioTeixeira
Hi there,
Have we any integration possibility with Wireless Controller C1-AIR-CT5520-K9 + Access Points AIR-AP1832I-Z-K9 using Cisco Connected Mobile Experiences and Cisco Identity Services Engine?
It would be nice any integration, but have all networks viewed through the Meraki Dashboard will be perfect.
Any idea?
Regards,
FTeixeira
Hi @FabioTeixeira,
It's not possible to integrate a Cisco Controller with Meraki Dashboard. Can you provide more information, what do you need?
Hi @FabioTeixeira,
FabioTeixeira
Hi @alemabrahao , thanks for your help !!!
We have a client with large number of AP's AIR-AP1832I-Z-K9.
The main idea was start a Meraki project and replace these AP's progressively.
Well, I know that it is possible to use Cisco ISE with Meraki APs without problems, But I'm not sure about CMX, because Meraki has a Location Analytics integrated.
https://community.cisco.com/t5/security-knowledge-base/how-to-integrate-meraki-networks-with-ise/ta-...
In time, does your client use any CMX functionality in particular?
