Cisco Meraki - Access Point offline repeat notifications
ADF
We recently moved to Cisco Meraki Access Points at work .
In the Meraki portal we have setup to receive an email notification for when the Access Points lost connection to Meraki Cloud / Go Offline and we receive a notification when it re establish a connection to the Meraki Cloud / Go Online .
> We only receive one notification for Offline
> We only receive one notification for Online
Is there a way in Meraki Cloud portal to set it to send repeat notifications (Every hour etc. ) until we manually disable further notifications for that device ?
*eg. If its a faulty device or expected outage
I have done some Google searches but don't seem to find that functionality mentioned ?
KarstenI
I am not aware the the dashboard has this much flexibility. This is typically done with an on-prem NMS (CheckMK/PRTG/NAGIOS/whatever) that polls the devices and reports appropriate.
BrandonS
There are some cloud syslog servers that could do this too.  I use https://papertrailapp.com and then you can set alerts quite easily and define how often to get alerts, disable specific alerts, etc.
CameronS
Maybe try your way with PRTG syslogging?
Agus
as mention above, that correct only have one notification if device disconnected to cloud. For further network monitoring we also add additional monitoring using cacti combine with ping template or with snmp template
i hope this help
Thank you
