2.4GHZ devices can connect to 5ghz?
Tarmahmood1
If we turnoff 2.4ghz, is there any negative consequences, that  devices not supporting 5Ghz can connect to network or not?
Devices that do not support 5Ghz will not connect to the network, as they are different frequencies.
https://www.centurylink.com/home/help/internet/wireless/which-frequency-should-you-use.html#:~:text=....
BlakeRichardson
Yes you won't be able to use them.
TBHPTL
We go rid of 2.4GHz a long time ago. I can honestly say its has made the world a much better place. Have only had 2 complaints in 5 years.
BuDo_KSBA
You could first have a try to reduce the radio power of 2.4GHz and enable band steering. If you still have one or two clients with 2.4 GHz, you could contact them. Or you could cut them out by disable the frequenzy 🙂
