Is there a place that Meraki posts documentation about MG firmware updates?
Solved! Go to Solution.
Not quite yet. Current version is 1.9 and there are not yet SRC or Beta versions of MG firmware. Fairly soon I'd expect to see MG release notes exposed for the different firmware versions in the same fashion as you see for other products under Organization > Firmware Upgrades. If there were specific firmware-related questions please reach out to Meraki Support or your local Meraki team to address prior to release notes becoming visible.
In addition. You have to go and find the device at the " all networks" tab. Its not in the overview yet.
>If you have the device in your inventory, it 'should' show up under Org>Firmware Upgrades
MG is so new it is not like the other products. It doesn't show up under firmware upgrades. You can't select a firm to use or to upgrade them.
