MG Firmware Notes
NJNetworkGuy100
MG Firmware Notes
Is there a place that Meraki posts documentation about MG firmware updates?
MerakiDave
Not quite yet.  Current version is 1.9 and there are not yet SRC or Beta versions of MG firmware.  Fairly soon I'd expect to see MG release notes exposed for the different firmware versions in the same fashion as you see for other products under Organization > Firmware Upgrades.  If there were specific firmware-related questions please reach out to Meraki Support or your local Meraki team to address prior to release notes becoming visible.
5 Replies 5
NolanHerring
If you have the device in your inventory, it 'should' show up under Org>Firmware Upgrades
From there you can click the version and see release notes.
I don't have one so I can't see it on my dashboard.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
In addition. You have to go and find the device at the " all networks"  tab. Its not in the overview  yet.
MG is so new it is not like the other products.  It doesn't show up under firmware upgrades.  You can't select a firm to use or to upgrade them.
MerakiDave
Pulkit_Mittal
Hi @NJNetworkGuy100,
Unfortunately, the only way is via dashboard.
Sharing link to best practices and process adopted by Meraki, https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
Hope you find this useful!
