The MA-ANT-C1-A comes with a 100cm antenna cable. Is it possible to use a 200cm cable?
Is there a Meraki productcode for available, or must i use third party cables?
Thanks!
Kinde regards
Ruud Nouris
Solved! Go to solution.
The leads are fixed to the antenna
The MA-ANT-C1-A is a dipole antenna for the MG21E. It has no cable as it directly attaches to the MG. Any cable extenders would be 3rd party.
Hi Ryan, sorry, I ment the MA-ANT-C1-B.
Same answer would apply. Any cabling beyond what's attached to the patch antenna would be non Meraki.
So can I replace the cable, or should I extend it. I mean is the antenna cable fixed to the antenna or is it connected via connectors.
