Can you force an mesh AP to join a specific root AP?
greaper
Is there a way to force a mesh AP to join a specific root AP?
Thank you!
You could put them onto manual channel assignment, and put the two onto the same 5Ghz channel.
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Using_a_Cisco_Meraki_Access_Point...
2 Replies 2
Bruce
You can't specify the AP for a Repeater to use as a Gateway so far as I'm aware. The Meraki Mesh uses a proprietary routing algorithm to determine the best path to use based on a number of metrics, so theoretically it will always make the best choice (but that's theory and not practice). There's a little bit on this topic in this document, https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Wireless_Mesh_Networking
