- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Is it possible to set different time zones within the same network
I know where to set time zone for a network but it only allows you to set one. I have devices in multiple time zones that I would prefer to keep in the same network.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Just reread the question.....so you have devices in different Time Zones so I'm assuming these are geographically dispersed. You can only set a single Time Zone for each network so the answer to your query would be no.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
a way around this though, which is common practice from a security perspective is set all devices to UTC time.
This way all devices log with the same time markers, and if you are looking for issues between sites across the globe issues should be easy to find.
