some computer can not see networks
Hi team,
I have a net with MX,MS and MR. The SSIDs working good  but few computers don't see the SSIDs created, it can see the orthers net close to the building but not the ones I created.
Example: One computer have the problem is a I7 generation 8, It no the problmen Min. Bitrate in RF Profiles.
The weird thing is only few computers can't see the SSIDs and the other don't have problem.
what would be the problem?
Thanks and Goodnight.
Accepted Solutions
Re: some computer can not see networks
How are your SSIDs configured:
  • Wireless > Access Control: Band selection
  • Wireless > Access Control: Minimum bitrate
  • Wireless > Radio Settings: Are you using RF Profiles for any of your access points
What kind of wireless adapter is in the client? E.g. Intel(R) Dual Band Wireless-AC 8260
https://www.thewindowsclub.com/how-to-find-out-which-wireless-card-is-present-in-your-laptop
4 REPLIES 4
Upgrade wireless adapter driver on those computers also make sure you have no sticky mack enable on that port Meraki is connected to it.
kav noroozi
Thanks, I checked but the problem continue. I upgrade wireless adapator, restart machine and working.
Thanks for your answer.
Thanks, I upgraded wireless adapator, restart machine and It working .I trusted of Machine Generation jejeje.
Have a good day
