WLAN PSK with less than 8 characters
Mamba123
Can you configure a PSK with less than 8 characters at Meraki?
If I try to configure a PSK with less than 8 characters, I get an error message that it should be at least 8 characters.
I know it's not safe.
But I still ask, can you set somewhere that smaller PSK are accepted.
Thanks.
rbnielsen
No, it is not possible to configure a PSK shorter than 8 characters.
LinkedIn ::: http://rbnielsen.dk
5 REPLIES 5
UCcert
Hi @Mamba123 - If security isn't a concern why not leave the SSID open?
Darren O'Connor | uccert.co.uk
there is a reason why I asked this question.
rbnielsen
Thanks, that was also my question.
JohnD
The WPA2 standard requires the PSK to be at least 8 characters, so this should be consistent across all compliant vendors (including clients), not just a Meraki specific thing.
